Front drive shaft angles
Discussion in 'The Garage' started by wfo163, Apr 23, 2004.
  1. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Is it possible to shave some metal out of my front drive shafts CV joint so it can move a little more. It is really limiting my suspensions movement not because it is too short just the the joint doesnt let it drop more than a few inches.
    K30 4inch lift
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes quite a few people do it. make sure you only do what you need though
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Absolutely. I had to do it just to hook up my driveshaft at ride height before I got my High Angle Driveline.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Absolutely not. Do it until the centering ball is the new bind point. If you're going to do it, remove the stops entirely.
  5. wfo163
    Jan 11, 2003
    100
    Charlotte, NC
    ONe more ?. Do I need to disassemble the cv joint to do this or can I just move the joint and grind what I need to?
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just move the joint and grind where you need to. Grind until the yokes that hold the u joints are no longer what will make it bind from too much angle.
    This will move the binding point to the centering ball and allow you maximum angle that you're going to get from the Saginaw CV.
    If still not sufficient, call Jesse. /forums/images/graemlins/thumb.gif
  7. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    grind-away I had to get rid of quite a bit of the joint just to be able to drive at all. It's a very easy and quick fix.
