front drive shaft binds with lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kore0015, Mar 20, 2006.
  1. kore0015
    kore0015 Registered Member
    Mar 1, 2006
    9
    Ft Lewis, WA
    I put on a 6" suspension lift on and now my front drive shaft binds.
    The lift included a transfer case drop. I had a hard banging as soon as I locked in the hubs, so I crawled underneath. The problem is on the transfer case side of the shaft. What I see is that the U-joint is banging into a pair of tabs on either side of the shaft. I was going to have a drive shaft place grind off the tabs, to see if that fixes it. Maybe I need a longer shaft or different style joints?
    I was just curious if anyone else had similar problems. I hadn't heard or seen any issues like this. I don't know. Still fairly new to the offroad/upgrade world.
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Just grind off the tabs. That should give you the proper clearance.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Why have a drive shaft place do it? Do it yourself
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I am suprised the instructions with your lift kit didn't tell you where to grind the front joint. As said. Its a simple job Just grind enough off of them to get clearence you need.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i havent looked at my shaft recently, but where are the tabs that can be ground off?
  6. kore0015
    Mar 1, 2006
    9
    Ft Lewis, WA
    The 2 tabs I'm talking about are on either side of the front drive shaft at the transfer case end right before the joint. If memory serves me they stick out about a quarter inch and are maybe half an inch wide.
  7. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    I have a 6 lift on my jimmy and havnt had any poblems with the front driveshaft. I was thinking the other day though. Being a cv shaft, shouldnt the front axle be rolled up like the rear. Isnt that propper driveline geometry. But rolling it up would screw up your front steering and camber and caster angles.
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    get an angle grinder and grind them like this
