Front drive shaft interchangeability ?s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Nov 14, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    the slip joint on my front drive shaft is worn out, so I'm going to the junk yard friday to see if I can find one in better condition. Will a drive shaft from a k5/pickup/suburban with a different transmission/transfer case/axles fit without problems?
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. [​IMG] Different transmissions and t-cases are different lengths. Also, some t-cases have a square flange at the front output, while others use a more typical yoke. You'll want to measure carefully to make sure you get a driveshaft that is the right length and has the correct ends.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A driveshaft from any GM truck of this bodystyle with the same tranny/xfer and the same front output on the xfer will work.
    A TH 400 is I think 2-3 inches longer than a TH 350, and a 700R4 is longer yet....so none of those shafts will work.
    Right now I've got the front shaft from a TH 400 truck on mine and it's a bit short. I'll upgrade soon.
    Your tranny/xfer combo is quite common, and if you've got the flange and not a yoke up front, it'll be really easy to find a shaft.
    Tim
  4. Jonathan
    Apr 14, 2001
    293
    Ok so I'm gonna have to find one from a th350/np203, hopefully they'll have one this time. Thanks
