front drive shaft leaking (10 bolt)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Jul 23, 2003.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I noticed a previous post about a dana axle leaking from behind the u joint, as with his mine is doing the same thing, i was wondering if the procedure to replace the seal will be the same on the 10 as it is on the Dana. Ive completely torn apart the hubs multiple times and ive done the gears as well, but ive never seen this seal that the guy gave me at the parts store /forums/images/graemlins/confused.gif
    Can you guys gimme some help on this one, thanks
  2. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    it is just like a 44 remove the axle shafts and pull the carrier the seals r in there
    Kevin /forums/images/graemlins/k5.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Does a D44 front use a solid spacer or a crush sleeve?
  4. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    dana 44 uses shims all dana axles use shims. corporate axles use crush sleeves
    Kevin
