Front drive shaft lengthening and balancing???
Discussion in 'The Garage' started by 87GMCJimmy, Mar 3, 2003.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Would you lengthen your front shaft yourself? You could do a crude balancing by hanging it from a string, kinda like balancing your ceiling fan (Or some other method I'm sure could be better). I figure the fastest I'd ever see in 4 wheel is 40-45 and that would be pretty rare. As long as the balancing was close I don't think you'd take out t-case or pinion bearings and seals.
    Anyone done this? Any good reason not to try?
    Thanks,
    Mike
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Old school balancing method: After placing the truck on some good safety stands put the truck in gear and run it up to 45 or 50 mph. Take a piece of chalk and hold it close to the driveshaft until it barely touches. Then put a hose clamp with the worm screw opposite the mark you made. It sounds stupid but it's gotta be better than hanging it next to a plumb line. Use your own discretion.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Why would you want to balance a front, unless it was fulltime??? Don't waste the effort, IMHO...
  4. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    That's what I was thinking. Why not. As long as it's close.(Straight)....
    Dunno, I guess I'll try it and see.
    Mike
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Hi Mike
    I too am in the Phoenix area. This is not what you are asking but I'll tell you just to let you know.
    I had a new one made a Dick's Driveline for $186 (I think) with an exchange. They lengthened it one inch for my 4 inch lift. I was told they were the cheapest around and did a good job so I had both front and rear done there.
    I too would not worry about balancing it. You will never notice it unless you like driving it in 4Hi on our dry streets.
    Good Luck
