Front drive shaft M1008 np205
Discussion in 'Parts & Trucks Wanted' started by 4xfreak, Jan 12, 2003.
  1. 4xfreak
    4xfreak Registered Member
    Sep 29, 2002
    78
    Bay Area, CA
    I recently installed my np205 and everything went well except for the fact that my old front drive shaft that I used with the 208 t case does not work with the 205. It over shoots the front axle yolk by about 4" at full compression /forums/images/graemlins/mad.gif I thought it would be simpler than that but I guess not. So I need a front drive shaft that will fit a np205 equipped one ton truck w/ d60 front end. The weird part about it is the old drive shaft has a half ton u joint on the pinion end. Any help is appreciated /forums/images/graemlins/thumb.gif
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    you can just have yours shortened or do it your self thats what i did i just cut the weld loose on the front spline shaft and then cut the tube down to what you need and just weld it back in and my front driveshaft had the 1/2 ton u joint it hooked rite up to my 60
  3. 4xfreak
    Sep 29, 2002
    78
    Bay Area, CA
    Looks like I will have to get it shortened. But I kinda want to find one for when I lift my truck in case it is too short then.
