Front Drive-Shaft Question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadBowTie, Jun 14, 2000.
  1. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Mine has always sorta spewed grease out of the bottom end. It would seem to me that their should be some sort of plug in their to keep the grease in, I thought I saw them plugged on military Blazers. Should mine have one? If so where do I get one?
    Rick
    86 K-5
    http://www.BigBadBowTie.ColoradoK5.com
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Do you mean that hole just behind the lower u-joint? You can't plug it, when the driveshaft shortens, the inner part of the shaft forces air out that hole at high speed. It's sorta like a bicycle pump. As it lengthens it's on the intake stroke... [​IMG]
    http://ThunderTruck.ColoradoK5.com
