Front drive shaft questions
Discussion in 'The Garage' started by MilpitasK5, Dec 19, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    What is the small part of the front drive shaft called? I have an 86' with 10bolts (if that makes any difference).
    There is a small cover type thing that holds in the grease. What is that called? Can I buy that part seperately or would I need to get a new front part of the drive shaft.
    Sorry I don't know what all that stuff is called.
    Thanks!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Just the gasket or the the part that threads on , if it's the gasket , I just used a rubber washer from the plumbing section.... /forums/images/graemlins/thumb.gif
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I don't think it's just a gasket. There's a hole like there should be some type of cover on it to hold in the grease. Can I just try to stuff it with something rubber? Should that piece be open?
    Thanks for your help! /forums/images/graemlins/ears.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you are referring to the front yoke of the driveshaft which attaches to the front differential yoke then YES, there is a small plug with a hole in it. You can simply find a proper size concave freeze plug and install it there. Sometimes people weld the plugs in place.
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    "Concave freezeplug" it is then! /forums/images/graemlins/thumb.gif
    What is that and where could I get it? /forums/images/graemlins/ears.gif
    Thanks Scott! /forums/images/graemlins/thumb.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Bring your yoke to my shop tomorrow and I will hook you up with what you need. I will only be working tomorrow and half a day monday then closing shop til next year.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Sure it's not a Zerk fitting?
