Front Drive shaft vs y pipe
Discussion in 'The Garage' started by stockk5, Feb 27, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Ever since i put in my 4" lift on i notice that my front driveshaft hits my y pipe of the exhaust, i've noticed now there is a small smooth silver area around the front drive shaft from it rubbing on the pipe, it doesnt rub at all times but anytime i go off-road it does, is there any cheap fix to this other than a whole new header back system? If i leave it will it compromise the balance of the driveshaft and mess lots of stuff up? thanks Mike
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mines been rubbing for a year now that I lifted my truck . I have been putting off replacing it for a bit now . Its mostly on pass droop I assume . I would say fix it , but have no room to talk until I fix mine ;)
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Take it to a exhuast shop and have them cut out the part that's hitting and then weld in a newly formed, (read: one that drops a bit lower) . Problem solved..
    I've had to have it done a few times (on different trucks over the years)... usually never costs very much, but just to be sure, make sure you get a price first.
  4. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    ya it cost me 40 bucks for them to do mine the only bad thing is how far that drop is i will be the one of the first things to go on a rocky trail.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Hmmm.... Seems like the time to put "true" duals on.
  6. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i wish i could get true duals.... someday!
  7. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    so whats up with this TRUE duel exhaust ether you have duel or you don't right or am i missing somthing here? it's not to much to have some one run a straight pipe to a muffler and get away from that y pipe.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I bought an elbow from autozone for $3, cut out the section that was touching and welded the elbow in. It gave me about 1 inch of clearance. Cut out a smaller section than the elbow, fit it up and weld it in.
    I did it as a fix until I have the money/time to put on duals, but it works fine and has for months including some fun crawling.
  9. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    My Y-pipe split right thru the weld, no more clearance issue and gave me a reason to get dual exhaust, :D
