front drive shaft worn?
Discussion in 'The Garage' started by MUD JUNKIE, Oct 19, 2002.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    my front drive shaft is worn were the two slide together,the splines are way worn and have alot of movement,or "play" can this be rebuilt? I also have a front driveshaft off the same truck but a 3/4 ton and its the cv front shaft type,it uses a different bolt type to attach to the yoke on the output yoke on the t-case,could I just use thru bolts (grade 5) to bolt it on the yoke? or do I have to buy another yoke for the output yoke on the t-case? help im lost??? /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    When I did my suspension lift, I had to have new drive shafts made. I think your best (safest) thing to do is that.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well if i was you, id use the driveshaft you already got, as long as its not wern down, and id probly use grade 8 bolts, grade 5 would probly work, i think those are the ones holding my front drive shaft on the yoke of the t-case. good luck and happy trails.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
