front drive shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Nov 18, 2001.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i just did the lift on my truck and the front drive shaftrubs up agaist the cross over pipe on my exhaust. can i take the front drive shaft out and still be able to drive it, because i've got to lower the transfer case. its a 1991 with a np241...
    high
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Yes, you can take the driveshaft out and still run it. Just don't put it in 4wd. Eight bolts and it's out. (grease your CV joint centering ball while it's out too, trust me on this one...)
    Why do people keep calling it a Bronco!!!!! <img src="http://coloradok5.com/forums/images/icons/mad.gif">
  3. CV202
    Nov 14, 2000
    454
    Kingfield, ME
    Yes, you can take the driveshaft out and still run it. Just don't put it in 4wd. Eight bolts and it's out. (grease your CV joint while it's out too, trust me on this one...)
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Remember dont go out and play without it in though. IT sucks when you have a 4x4 and cant use it.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    My front driveshaft is off on my NP 241 and I still put it in 4x4. Doesn't hurt it, the front drivshaft is a fixed yoke, so it keeps the lube in. It's just like having 2 Low. Just make sure you don't floor it on the street in Low, you'll blow up the axle. I'm surprised at what this thing can do in 2. Nothing like blasting around in the mud.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I know you can still put it in 4 wheel drive buy when I go out I always need 4 wheel drive. Just like today I went out and had to test 4 low again :) I found two ditches dug out in the field behind me. They were right nest to one another and both were 3 1/2 foot drops. One you started to get out of the first one you went into the second one. I dragged my gas tank and hitch all the way though. Its a good thing the tank has a shield and I am locked front and rear :)
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I had to get my crossover pipe rerouted so I ran the truck for a while with no front driveshaft. If its legal in your state, go with true dual pipes, keeps everything nice and neat.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
