Front Drive Shaft?
Discussion in 'OffRoad Design' started by i_4x4, Mar 21, 2002.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I currently am running 350/208 combo. W/ my tax return i'm planning on getting a Doubler. I need a new front shaft. My question. Is the length of my current set up pretty close to what the doubler will be?( meaning from flange to yoke.) I don't want to buy 2 front shafts. Hopefully this makes sense.
    Later Ed
  2. schneggie
    schneggie 1/2 ton status
    Aug 24, 2000
    279
    Colorado Springs, Colo
    It makes perfect sense. I just put the doubler in mmine and had to extend the front shaft about 6 inches. I would wait if possible
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Wait to measure it so you know for sure. I'm not sure why greg's ended up that much longer, he should have been more like 3-4" longer than before but who knows. I have a friend that lucked out and was able to use a stock driveshaft from a 700R4/208 truck. He had a TH350 with the GEN2 rotated up along with a 2" lift. It was handy. I've messed with the length of some of my fronts just by cutting them in two and sleeving them inside or outside with another tube and welding it back up. Works fine for slower speed use.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I would suggest taking measurements. Stephen is probably correct on t he length issues. I had to have a front driveshaft for my 79 K10 one ton on 44s. I bought a hi angle 1350 shaft with the "rockcrawler slip". I paid just a little extra for an extra 4" of slip. With my current setup, I will have 3" of compression and 11" of extension with 2" of contact minimum. When I get a doubler is a year or so, I will let it extend about 4". That will net me 7" of compression, 7" of extension and 2" minimum spline contact. Let me know if you are unclear on what I am describing. My shaft came from driveline solutions. I talked to Oscar and he knew his S@#T.
