Front Driveline Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kombi59, Dec 20, 2003.
  1. kombi59
    kombi59 1/2 ton status
    Nov 15, 2002
    197
    Hey Guys, Here's one for you. I have a 6" procomp lift on my 84 k5 the transfer case cross member has the sleeve type spacers on it. the front axle has an angle wedge under the springs, the driveshaft is at a good angle. when in 4 wheel drive the front drive line u-jount Knuckle rubs the cross member when the axle drops. just very slightly. only enough to keep off the dirt. but it sounds horrible. any ideas? /forums/images/graemlins/confused.gif thanks in advance, Chad. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    With that kind of suspension lift, you probably want to get a spacer machined to fit between the flange of the constant velocity joint and the output shaft flange. About a 1/2" to 3/4" thick. Then get some longer grade 8 bolts. By doing this you push the whole assembly forward, which should free up some clearance in there. Also would put a little more contact groove to groove in your front shaft slip joint. Another probably cheaper route is to put a cable from the frame to go around the axle, to limit upward spring recoil. You might be able to work the crossmember a little with a grinder, just don't take off too much as to weaken it, otherwise you will have to reinforce it by welding some metal to the bottom.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Superlift makes a driveshaft spacer for what your looking for.
    Superlift #4310
    Thats for the 208 front output. /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you have your crossmember off, clearance grind it. I did mine a little bit when I had it off a few years ago. Between clearancing the shaft and the crossmember, no more rubbing issues since then!
  5. kombi59
    Nov 15, 2002
    197
    Thanks Guys, I'll try the spacer. Chad. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
