front driveshaft 36-40" range
Discussion in 'Parts & Trucks Wanted' started by muddybuddy, Oct 26, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive 8" lift + zero rates with axle moved forward 1.5", need front drive shaft 36-40" to work with np208. if the shaft is off a d60 i dont mind gettting conversion u-joint to make it work. let me know what you got :D
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    All front driveshafts of the same vintages use the same size u-joints.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i ment like if it had like a 1350 u-joints or somethin to be compatable with my s44 for the 10b.
    i understand what your saying tho, thanks :D
    ttt
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    get your shaft retubed. i have my shop in town do it for around 50-70 bucks with balence.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thats what i may end up doing...i ended up gettin my rear lengthened, til i go fixed yoke. i was quoted bout $100 to lengthen it, but ended up bein $215 cuz they said that the yokes from the facory werent machined, so they couldnt be attached to the new tube, and that i needed new ones...so for $215 i got a brand new rear driveshaft, i guess that isnt that bad....
    jus thought id check on here first, lemme know if u got one ;)
