Front Driveshaft and exhaust clearance?
Discussion in 'The Garage' started by stockk5, Dec 18, 2004.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    I just finished putting on the 4" rough country lift. I lowered the tranfer case like they said and now my exhaust and front drive shaft have about the space of 2 or 3cd's tall between them. Is this normal? Will it ever hit when flexing? Thanks Mike
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    That is a chevy y-pipe and a lift for you. They can rub, mine did with a 6" lift. This would be a good time to go to a custom exhaust system. :cool: :D
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I'm having the same problem just mine is rubbing. Called a guy at a local muffler shop and he said that it should be cheap to cut and lower the pipe. Let me know what you do as I have to fix mine soon.
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    it probly will. i've got 3" lift and it rubs under full flex. you can either have a muffler shop make you a new pipe, have them put a dent in it, or buy some thorley headers that come with new pipe that dips down for lifted trucks.
    or just let the shaft rub on it when your flexin.
  5. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    argh...hm i know a friend who welds for a living.. and bends tubing all the time. ill prob run it for now then have him make a custom bend there.
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    A lot of guys that don't just remove the y-pipe reroute it over the top of the shaft.
  7. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i remember considering over the top, but i think it looks pretty tight with only 3" of lift.not much room for compression. i'd say your 4" will probly look similar. maybe on a 6-8" lift it would make more sense. what i have seen that looked cool was routing it straight back past the Tcase and over the rear shaft. didnt look like i'd have enough room in my truck for that route but it is something to think about
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine rubs flexing , I had it tucked up for clearance when stock exhaust replaced , never realizing a couple years later it would rub lifted . I actually rub on my crossmember worse than my exhaust :xmas:
  9. cbbr
    Jul 17, 2004
    14,681
    THe mechanic that looked at mine recommends routing it above the shaft. Will this cause trouble for the tranny? Seems like a lot of heat close to the tranny pan. Not a bother at highway speed (maybe) but will get hot on the rocks. Anyone done this/had any problems?
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Raise your t-case back up, 4" lift, no need for lowering it.
  11. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    bad vibrations is a reason
  12. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    if you're gonna rub your y-pipe, do it in private...
    cut of the y-pipe, put a cap on it, and add a complete exhaust system to the other side. My truck had dual exhaust when i got it, but that's probably what i would have done in your situation.
  13. cbbr
    Jul 17, 2004
    14,681
    Duals running off of the stock manifold or with headers?
  14. BURBicon
    Dec 11, 2004
    78
    Sunny Phoenix
    well that depends on how much money ya' got.
  15. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i had to lower mine with only 2 1/2" lift. the vibes werent horrible but it definatly wasnt vibe free.
    the shorty driveshafts on blazers are lame. i want to do a SYE and CV joint shaft.
    if you dont smog your truck, go ahead and run duals. if your truck needs to be smogged, it wont even make it onto the machine before they fail it.
  16. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah,my bad, i have a burb, has longer driveshafts, didn't need to do anything with the T-Case.
  17. cbbr
    Jul 17, 2004
    14,681
    Did you have front driveshaft/y pipe issues with your 4" lift.
  18. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    ya right 4 inch lift will cause bad vibes from short wheel base man. mine did and i had to lower the t-case and shim the axles so it wouldnt vibrate like hell
  19. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Mine have no issue with clearance, the pipe is really close, and has rubbed alittle, but nothing to extreme to cause any concern with, BTW it is still the stock pipe. I even run with sway bar disco's for that extra travel, still no problems. As far as vibrations, i don't have any problems, but this is probably due to the longer driveshaft of the Burb, the angles are not as harsh as the shorter Blazers.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    lowering the transfer case is a bad idea in my opinion.
