Front driveshaft balancing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dysphemism, Jan 21, 2002.
  1. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    I am going to be having my front driveshaft redone to fit my new Dana 60. I was wondering if I can simply remove the front half of it, seperating it at the slip yoke, or if I need to take the entire driveshaft in? It is already balanced for my 10 bolt.
    Beefing up my truck broken part by broken part.
    1986 GMC Jimmy 9" lift, 38" swampers, and a sarcastic liscense plate holder.
  2. dyeager535
    26,979
    You need to take the whole thing in.
    Two piece driveshafts are where you get in to "phasing" problems, so make sure if you take it apart, that the front and rear u-joints are oriented the same way.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
