Front Driveshaft Clearance
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Dec 3, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    For those of you running a 700r4 (and especially those with a swapped in NP205 t-case, which is the combo I have), how much lift do you have and what is the clearance between the front driveshaft and the tranny pan. The reason I ask is I have a 4" lift and noticed that my pan was leaking slightly. Upon furthur inspection I noticed the driveshaft (the CV portion) was hitting the pan under slight compression. Any one else have this issue?
    TIA
    Chris
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I took my pan and with a body hammer and backing dolly reshaped the right rear portion to clear the CV joint. There is about 1/4" clearance between the CV and pan now. Haven't hit it yet. Looking for another pan to modify by cutting this area out and weldong in another section. Can take pic's and send them to you if you want.
    Wheels
    Also running a 4" lift.
    <P ID="edit"><FONT class="small">Edited by Wheels on 12/04/01 09:52 AM.</FONT></P>
  3. Leadfoot
    Nov 28, 2000
    3,112
    Thanks for the reply.
    I was planning on doing something similar, but wasn't sure if the valve body or any other internals were in the way (I don't remember from dropping the pan last time). I am dropping the pan this winter and will cut a section out and weld a new one in for clearance. I was just going to persuade it a little first (without removing the pan) but just wanted to make sure there was nothing directly behind it. Pics would be cool Thanks.
    P.S. Now I now why Stephen went with the driver's side drop on his 700/205 combo (more room).
    Anybody know why the other t-cases work without interferance from the d-shaft. Do they drop furthur down?
  4. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Just like Wheels said, you will need to push in that corner of the trany pan. If you are running a 1350 cv you will need all the room you can get. Good luck
    MAC
