Front driveshaft CV binding, would a 1410 be better?
Discussion in 'The Garage' started by 8_YOUR_H2, Sep 6, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have a 1310 flange style front out put on my 205. I had the driveshaft shop grind the CV for more flex but it still binds up pretty bad and will not allow full droop of the passenger side front.
    Would a regular 1410 U joint allow me more down travel?
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Get ahold of Jesse at High Angle Driveline ( http://www.highangledriveline.com/) and chat him up. I have his 1410 front CV driveshaft and it flexes quite well. However, it is a monster and takes up a lot of space. I have mine on a doubler setup.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    If you surch Mudzerwhateverhisnameis he's got a post, way back where he put a 1350 cv center section in the 1310 cv and he got some serious working angle.
    edit: I've got the same front shaft and DR. The thing is major beef.
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    1410/1410 shaft will run at 29+ degrees without bind. Front shafts aren't fulltime high speed applications anyways so that's what I chose to run. If it isn't enough I'll run some Tom Woods superjoints at either end.
    Rene
  5. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Rene, do you run a CV or just a single 1410 on both ends?
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    He is gonna run 1410s at both ends non CV on both shafts:D Something about equal length shafts and only needing 1 spare shaft/joint.
    Ira
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    makes perfect sense if you can run it:bow:
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    That is the plan...I'll get some final driveline measurements pretty soon and see if that's going to be possible or not.
    Rene
  9. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Wow that HAD CV is bad ass, I don't think it would fit in my crossmember though. I had their 1350 CV on my old K5 and it was awesome too.
    Thanks for the info all.
