Front Driveshaft has no give
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rivermtnman, May 20, 2006.
  1. rivermtnman
    rivermtnman 1/2 ton status
    Nov 7, 2003
    102
    Lebanon, VA
    Trying to get the blazer ready for Harlan, installed 4" lift, and realized the front driveshaft has seized up in the splines. Never seen this before, so I put the heat on it and try to beat it off, with no luck. I've not had the blazer for the past 2 years, and got it back with the rear end out of it. I cant imagine why it wont move, but the more I think about it, could the splines be twisted? Any ideas?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    could be twisted or could be rusted together. sounds like u need a new shaft
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    :haha: :haha: :haha:
    sorry couldnt resest. Probly just old grease and dirt.wd 40 or carb cleaner :dunno:
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Dont beat off.......
    Gotta agree with delory. Old grease and dirt will make your front shaft tighter than an 80 year old virgin. Pull your shaft, lube it up with some nut buster. Squirt as much as you can down the hole in the middle of the shaft and all over your shaft/splines. Work it Hard...... in and out........ and in and out. Squirt, squirt, squirt.... in and out.. in and out. Once you get the rythym itl cum apart like magik... Your splines aint twisted.... just all sized up from lack of use. Work it out boy........
  5. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    ROFLMAO :haha: , I knew I shouldn't have wrote it like that but was the only way to describe. I sprayed it with WD-40 a couple of days before I put the torch to it. I'll keep tryin... Thanks all. Hope to see some of y'all in Harlan. If I cant get this Blazer goin, I'll bring the old CUCV.
  6. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    :haha: :haha: :haha: :haha:
  7. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    are we still talking about driveshafts here?? :haha: :haha: :haha:
  8. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    OK back to the subject... I got the driveshaft wrapped with a chain on both ends, with my hi lift between the chain, and we just bent the handle on the hi lift jack, while beating on the yoke and it moved about 1" before I decided not to ruin the handle. I was going to try a tug-o-war between my truck and the tractor with the driveshaft in between, but dad thinks I've got more pressure on it with the jack then I could put on it between 2 vehicles. I'll fight with it a little more, but will start searching the local yards for one since I need it this week. Will 1/2T truck front driveshafts fit blazers?
  9. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    Get a tourch and heat it up
    look for a tuck/burb/blazer with the same trans/ tcase combo as yours and it should work
