Front Driveshaft Help
Discussion in 'The Garage' started by wforicv, Dec 24, 2004.
  1. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    My front driveshaft is trashed on my '87 K5. Have searched all junkyards around my area with no luck. I am fairly new to all this and have been told that a shaft off of certain 1500 pickups will work. Is this true? I am in the process of finding a 60 for the front, so I do not want to spend $300.00 I was quoted by a local driveshaft fab shop. I would like to find a something less expensive to last for a while until I can get my hands on a 60. Any help will be appreciated.
  2. spartan4x4
    spartan4x4 Registered Member
    Nov 30, 2004
    18
    SC
    I would think a k10 would have the same front shaft, it shares the same front leaf springs, axles, engine/tranny/tcase combo as a k5, so i'm 99.9% sure it would work. when you swap the 60 in the front you'll have to swap the slip yoke or get a conversion joint ($$). if you can get a good used shaft then you might end up money ahead just make sure the CV isn't shot and the slip & spline doesn't have alot of play.
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    A Stock Dana 60 uses the same Ujoint as a Dana 44.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I have one out of my '87 Chevy (With 75,000 miles on it), i'll sell you for $75+ the ride to your house.
  5. wforicv
    Feb 16, 2004
    165
    Just talked to a friend who says he has one out of a k10 in good shape that will fit. I am going to check it out tomorrow afternoon. jwduke, I will get back with you if his will not work. You guys rule, thanks!
  6. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    For my 90 K5 I used a front shaft off of a 1997 suburban. It was only $50 at the junkyard and works great :xmas:
  7. 86gmcjimmy
    86gmcjimmy Registered Member
    Apr 1, 2004
    16
    wa
    you can use any front drive shaft 73-91 they are all the same I used on from a 78 3/4 on my stock axles
  8. diesel4me
    Jul 24, 2003
    17,540
    925
    Massachussetts
    Mopar(ts)
    If any of you guys have the "old" style front shaft that has the 4 bolt yoke at the transfer case with 4 threaded holes in the CV yoke(you know,the ones that suck to remove because the crossmember is in the way!)-they used it on the 69-72 K trucks,and some later years depending on what T-case it had---a front driveshaft from an 80's dodge dakota 4x4 pickup I found at the boneyard is identical to the GM shaft,length,u-joints and all--the guy at the junkyard tells me since he had more dakota's than chevy 4x4's,he often sells the dakota shafts in place of the GM ones...and the Hollander interchange book doesnt mention the dakota shaft as an alternative,but he claims its a bolt in!!..:crazy:
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  10. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
