front driveshaft length and front lifting Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 27, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ive got a line on a 30 3/16" long(overall)- when completely collapsed- front shaft, and my measurement on the truck from t case mounting output flange up to the axle yoke is 30 3/4"
    that give me 9/16" of an inch
    i assume that is not enough, that i either need to lift the truck or do something else ?
    how much will lifting truck about 2" help, if any ?
    what are my options?
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    move front axle forward
    buy a shaft that is correct length
    shorten that shaft
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    was afraid of that, trying to find out for sure whether motion of front suspension binding down on street use could be enough to bottom out driveshaft when is only 9/16" to go before its bottomed out,
    do front suspension geometry changes- while street driving- actually cause that much length changes to front shaft anyways ?
    thanks
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    lift springs move enough to pound the shackle into the frame on compression
    it would suck to knock the transfercase off the back of the tranny
