Front Driveshaft on a '77 k5 PLEASE HELP
Discussion in 'The Garage' started by mtnman210, Feb 2, 2004.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Front Driveshaft on a \'77 k5 PLEASE HELP
    Does anybody out there have any suggestions to a problem I'm having with my front driveshaft. I have a 77 k5 Blazer and just put a 6in lift on it. the length is fine on the shaft but the angle is to steep I think. From what I can tell is t he knuckles coming out of the transfer case are hitting eachother and blowing out the ujoints. I've ground them down but the angle is still a little too steep for any hard prolonged use. If anyone has any suggestions I'd really appreciate it. Thanks
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Re: Front Driveshaft on a \'77 k5 PLEASE HELP
    grind more. i will try to dig up some pics if youd like. is your front driveshaft a flange or yoke mount?
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    It's the cv-joint thats hitting
  4. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    GREAT pictures on webshots...awesome
  5. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    how does your front driveshaft attach to your tcase. is it a yoke style or flange? a yoke style has 4 small fine thread 7/16 head'ed bolts. a flange style has 4 course thread bolts with a or 5/8 head IIRC.
  6. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    It's the flange 4 course thread bolts with a or 5/8 head... then between the tcase and the driveshaft ther's a 2 inch superlift spacer
  7. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    how about angleing your front axle up a little to help the angle and lower your t case alittle
  8. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I thought of that but really I can't rotate it enough to make help i don't think because it will screw up my steering
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Here's what I did...and I have a D60...
    1. Drop your t-case an inch.
    2. Grind c/v.
    3. Angle pinion 4*.
