Front driveshaft problem w/6" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudbogAD, Jul 26, 2002.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Front driveshaft problem w/6\" lift
    I never knew what I was getting into when I got a 6" lift /forums/images/icons/frown.gif . I got my rear driveline balanced and new u-joints put in and that took care of my bad vibe. The problem is when I put my front driveline back in while my rear driveline was in the shop, it hit/grinded on the transfercase crossmember /forums/images/icons/mad.gif . I grinded the cv-joints just as I was told but it still grinds bad. It only grinds when torque is applied. What should I do? Thanks for the help.
    -Adam
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Front driveshaft problem w/6\" lift
    did you lower the case??
