front driveshaft problems w/ 6in lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gritdog, Apr 16, 2002.
  1. gritdog
    gritdog Registered Member
    Apr 16, 2002
    12
    Rock Hill SC
    After installing front 6in lift springs and a front driveshaft spacer on a 78 Chevy PU, I am still having driveshaft rotation problems....Popping and binding.
    Is it standard practice to remove "lugs or stops" from around
    the u joint area? Are there any other mods that may help?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Did your front springs come with shims to correct for the angle? Might want to try some small shims in there if it didn't...
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You can usually get away with a little bit of grinding on it to help clear it up. You might want to consider dropping the transfer some. I run a six inch lift and went ahead and bought a high angle CVC joint which took care of everything. But if your looking to save a buck, Drop the T-case. Sometimes there are spacers on top of the framerail on the crossmember bolts, just put them between the frame and the crossmember.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes you can clearance grind the CV joint.
    Superlift makes a 1" driveshaft spacer that's cheap and may avoid a new shaft.
    Otherwise, find a stock shaft that is longer than yours and shorten it. If you have a TH 350, a 700R4 tranny is longer and might get you a longer driveshaft. Even a TH 400 is slightly longer than a TH 350.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Take a die grinder or a Dremmel tool and clearance it.
    You should be able to see where it is binding.
    -- Mike
  6. gritdog
    Apr 16, 2002
    12
    Rock Hill SC
    Thank you all for your help!!! First time on the message board.
    I will try these mods.
