front driveshaft question,for 6" or 8" lifts
Discussion in 'The Garage' started by MUD JUNKIE, Apr 19, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    front driveshaft question,for 6\" or 8\" lifts
    with a 6" or 8" suspension lift would the front drivshaft bind? its a cv type stock front shaft.this is also on a long wheelbase chevy pickup /forums/images/graemlins/thumb.gif
  2. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Re: front driveshaft question,for 6\" or 8\" lifts
    I've got a 6 inch lift and it was hitting the tcase crossmember. A 1 in spacer took care of that, other wise no problems.
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    what about on a 85 suburban with 7 inches of lift?
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Mine binds at the pinion when the u-bolt straps are cranked down. I originally thought it was binding at the CV but after playing around I figured out the pinion needs to be shimmed. Mine is a 1310 High angle and I have 7" of lift in the front.
  5. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    thanks I'll look into it
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I have 6" TuffCountry springs upfront and the cv binds only at fulldroop
