Front driveshaft question for an SM465/205 and Dana 60 with 6" of lift
Discussion in 'The Garage' started by TruckNutzDude, Oct 17, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Front driveshaft question for an SM465/205 and Dana 60 with 6\" of lift
    I never thought about how much shorter the SM465 was until I realized my Dana 60 had a longer center that moved the yoke farther back than the 10 bolt. On top of everything I added a 6" lift and am making the suspension capable of a lot of droop (maybe) I was thinking of ditching the new BDS springs for some 52's and moving the axle 2" foreward. Will I need the extra 2" or can I get away with a stock CV joint and a new tube for the stock shaft? I'm absolutely broke right now and just need something to work before winter is here. I'm sorry if my question makes no sense, I was just in a car with a broken exhaust and I think I have some fumes in me. /forums/images/graemlins/crazy.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Re: Front driveshaft question for an SM465/205 and Dana 60 with 6\" of lift
    you can run a stock CV. I was running that exact setup for the past few years with no problems. Just grind the "tabs" on the cv for a little more clearance.
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I planned on grinding the tabs, thanks for the comforting words BurbBoy /forums/images/graemlins/waytogo.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    IMO, you're never going to make it survive.
    I only have 6" of lift with mine, and I bottomed out a 1 ton CV enough to make it blow its mind.
    The stock saginaw CV is insufficient here IMO.
