Front driveshaft Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rock.monkey, Jul 21, 2001.
  1. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Will a front driveshaft off a 208 with the flange, fit a 205 without the flange ,if i take the flange of the driveshaft? Or will it be too short?
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a front driveshaft question too.
    Which is longer, a front driveshaft from a 700R4/NP 208 combo, or a TH 400/NP 208 combo?
    Tim
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    what are you asking Bill? length you are probably on your own break out the tape.
    what year is the 208 in?
    what year is the 205? my 205 has a flange so i need to know what your 205 is out of to see if the u joint is the same.
    the 82-86 uses a saginaw u joint with 1.125"bearing caps pn.5-3147X
    a conversion 3147-1310 is available p#544U or 3022a conversion 3147-1350 is available p#3162
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm sure somebody knows--what's longer, a 700R4, or a TH400?
    Tim
  5. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    i definately would say the 700-r4 because of the overdrive wouldn't be too much, maybe like an 1" or 2"??? Correct me if i'm wrong. Later - Doug
    Doug Krebs
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I have a 208 w/flange and a 205 w/o flange.
    They do not use the same size caps, so you can't "splice" w/o cutting the driveshaft.
    Lift It, Lock It, LIVE IT!!!
  7. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    A th400 is 4" longer than a 350 , and a 700 is 1" longer than a 400,, Source: Advance adapters...
    " Wider IS Better!!!"<a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So, in other words, my current shaft is 1" shorter than my old one. Thanks!!
    Tim
  9. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I Tried To Use A 208 Shaft On A 205 After I Removed The Flange And It Wouldnt Fit And Was To Long .Had To Get One From A Wrecking Yard..
  10. rock.monkey
    Oct 28, 2000
    296
    Thanks!
    Bill Innes
    88' Jimmy
