front driveshaft removal ?
Discussion in 'The Garage' started by muddybuddy, Jun 15, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i have a 88k5 with np208 and i want to take the front driveshaft off because its currently against the y-pipe. what do i have to do to get it off? do i have to do anything to keep fluid from coming out when im driving? thanks
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    There are (4) bolts on the t-case flange that I think are 5/8".. Then there are (4) bolts on the axle end that are 7/16"... Remove all eight and pull the shaft. No fluid will leak...
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so i dont need to put something over it when im driving?
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    No, just take out the shaft and drive. If you need the shaft to stay still when you turn your wrench just lock you hubs or put the t-case in 4 wheel drive, this will keep the front d-shaft from turning when you try to loosen the bolts.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Fix the problem - don't take the shaft off. I got a small bend from Autozone, cut out a section and welded in the bend. Very simple and cheap, minimal welding skills required. It gave me about 1 1/2" of clearance between the shaft and the pipe. Just cut the pipe so that the cutout section is shorter than the bend and when you fit the bend in, your problem is solved for about $5 and 30 mins.
