Front Driveshaft Spacer??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lax037, Feb 8, 2002.
  1. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I'm going to be upgrading to a D60 400/205 14ff(all of which I got for $400) in my blazer. I also plan to add a 6" lift in this process. When I got the D60 and the 400/205 I got the front driveshaft as well. This shaft is probably going to be to short for this setup, could I put a 1" drivehsaft spacer in there to fix this, or is it going to completely through off my angles, in which case I'm going to have to cough up the money to have the driveshaft done right.
    Tom
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    it might work...with 6" on mine the front driveshaft would work though the exhaust crossover pipe was an issue...
    i would say to go ahead and get the driveshaft built right so you never have any problems with it...
    thats what im doing now...
    Later
    Just tap it in...tappity tap tap...
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I made a 1" steel spacer after I put on my 6" lift.Making a spacer was way cheaper than getting the shaft retubed.I think Superlift makes alumimum 1" spacers.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  4. lax037
    May 29, 2001
    49
    Long Island
    To add to my setup, the truck has a true dual exhaust, so there isn't the problem of the y pipe being in the way. Is the 400 that much closer that a spacer in the driveshaft will bind up my front driveshaft, due to the fact that it will be at to great an angle. I know with a 350, this isn't a problem, just wondering if it's going to be a problem with the 400
    Tom
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    How much do those SuperLift spacers cost?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  6. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    how do they look like? i might need one of these cause my driveshaft is hitting my xmember on that hump for the tcase moutn, but only when its flexing, my options are do some fab on the driveshaft or that spacer.
    phill
  7. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    The spacer is just a metal disc similar to a hockey puck with 4 holes drilled through it. Superlift sells them for about $50 and they come with the longer bolts. I've been running mine for bout a year with no problems, just retorque them once and a while.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lower your transfer case.
    Tim
  9. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    He said he was talking about the front shaft. If he lowered the case that would raise the the front output even further.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
