front driveshaft spacers?
Discussion in 'The Garage' started by shaun89, Oct 15, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    hey, im putting a 6" lift on my k5, and its a 50/50 on if u have to lenthen them or not. i saw a pic of a spacer for the front driveshaft, does anyone no where i could get one?
  2. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Mine came with the lift kit. I got a bunch of stuff from different companies but I think the spacer was in a superlift box but I'm not 100% sure. Even with the spacer though I had to length my d-shafts. The spacer just helps clear the cross member.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I ordered mine from 4wheelparts. Around $50.
  4. bernman
    bernman Registered Member
    Oct 4, 2005
    26
    ny
    depending on the pinion angle, the setup may bind in the cv, mine did, till i got rid of the cv all together, i would recommend a new shaft, i made mine with the 10 or 16 spline slip and stub, i dont remember, which will never wear out and spine like the stock stuff. i make driveshafts at my shop in buchanan ny.
  5. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I had alot of binding in the cv too. I just took a grinder to it and haven't had a problem with it since.
  6. bernman
    Oct 4, 2005
    26
    ny
    i grinded mine at first, but then i noticed my slip and stub were worn so i said forget it . and a new shaft went in
