Front driveshaft u-joint, internal snap rings or external??
Discussion in 'The Garage' started by 85mudblazin, Oct 2, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I noticed my front driveshaft, front u-joint is a gonner and it doesnt look like there are external snap rings that attach it to the driveshaft, I am thinking they got busted out and that is why the u-joint is loose, the new u-joint came with the external snap rings so I think they are external unless I got the wrong one, can someone tell me if the snap rings go on the out side or inside?? BTW this is for a 85 with a np208.
    -Chris
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the one at the pinion is external snap rings, you should be able to see the groves for the clips once you get the cap out.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yup, thanks I finally got the u-joint out of there, the last snap ring fits very tight to where the u-joint doesnt move as good as it would if it was loose, I think the yoke is bent a little, is it ok to run it like this??
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that seems to be normall, every ujoint i have put in is like this.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok good /forums/images/graemlins/thumb.gif
