front driveshaft u-joints
Discussion in 'The Garage' started by LittlecountryK15, Apr 13, 2005.
  1. LittlecountryK15
    LittlecountryK15 Registered Member
    Mar 30, 2005
    28
    Greenville,SC
    how do you remove the two u-joint that are on the front driveshaft right at the tranfercase?
    appears that they are pinned all the way through the yoke and through the cap of the u-joint and out the other side. Is that the way they are assembled? b/c the pin just crushes when you try to tap it out.
    its on a 85 GMC 3/4ton pickup
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I have no idea what you mean by "pinned". You should be able to remove the clips on the bearing caps and pound them out.
  3. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    sounds like the molded joints from factory. if pin on both sides then its plastic. take a torch and heat up yoke till plastic pops and all comes out. take care not to heat to a gloing red tho. just even heat all around yoke . and it smells real real bad so outside if possible and dont inhale.:D
  4. LittlecountryK15
    Mar 30, 2005
    28
    Greenville,SC
    let me see if I can figure out how to get a picture on here and let yall see what Im talking about
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I've also heard when heating them that the molton plastic seems to shoot out so watch for that! Burn hazard.
  6. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    [​IMG] here is a pic I HOPE
  7. bigcountryk5
    Mar 13, 2004
    931
    oh and how in the crap do i resize a pic? :grin: :dunno:
  8. LittlecountryK15
    Mar 30, 2005
    28
    Greenville,SC
    well we finnally got a pic up now how do I get the u-joints out of there....sorry about the size were both new to posting pics.
    are those pins the ones that I need to heat up or is there somethin else I need to do and if I do have to heat them up how to you go about replaceing the pins.......once again thanks for the help
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I use Irfanview to resize pics. Also, does your camera have a macro function? Either way, looks like you exceeded your minimum focal length there, try keeping a little more distance between the lens and what you're shooting.
    I'm not familiar with those types, but it looks like what the other guys are talking about.
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yea, that's the factory plastic fastener. Heat and remove.
  11. LittlecountryK15
    Mar 30, 2005
    28
    Greenville,SC
