Front driveshaft wont stop spinning
Discussion in 'The Garage' started by 86Cucvbeater, Nov 14, 2005.
  1. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    Hey I've got an 86 chevy with an np205 transfer case. When I'm in 2wd on the street or wherever, the front driveshaft wont stop spinning unless theres force against it(like if I stick a bar down there. theres a hole there in the floorboard). The cv joint on the transfer case end has play in it and needs to be rebuilt but that shouldn't make it freespin down the highway lol Any ideas?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    hubs engaged?
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I think they all do that. If you have one out of a truck, put it into 2Hi, and spin the input, the front output will spin also. If you hold the front output and continue to spin the input, the front output will stop with minimal resistance. My NP205 and my NP202 both do this.
  4. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Well I dont think mine ever did this before but maybe it always did and I just notice it now because the shaft makes noise wobbling around because of all the play in it. Anyone have the part number for a rebuilt kit for the front chevy stock cv?
  5. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    The 205s just do that. When the front shaft's gear is disengaged it is very close. The spinning oil slung by the other gears creates a paddle wheel effect and pushes the front shaft a little. Like you said, any resistance will stop it easily because it's not a mechanical connections. Don't worry about it, just praise the 205 for it's beefy awesomeness! :bow:
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    All t-cases will do this. It just means that the bearing are in good shape and everything is nice and free in there.
    My 208 does it also.
