FRONT DRIVESHAFT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudder, May 3, 2000.
  1. mudder
    mudder Registered Member
    May 3, 2000
    10
    CENTRAL KANSAS
    DO I NEED TO LENGTHEN THE FRONT DRIVESHAFT ON MY 77 GMC JIMMY TO ACCOMODATE FOR A SIX INCH SUSPENSION LIFT?
    TAKE IT TO THE MUD
  2. 78k5
    78k5 1/2 ton status
    Apr 25, 2000
    173
    Big Island, Va.
    I have a 6" superlift on my 78 k-5 and I need longer front and rear driveshafts
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    From my past experiences...mild wheeling...I'd say:
    For a 4 inch lift maybe, but for a 6 inch you will definitely need to have it lengthened. On a pickup you might get away with it, but something short wheelbase like a K5, no way.
    '73 K5
    Chevy good...Ford bad
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I tought the K series 10 1/2 ton truck, blazer have the same front driveshaft ?
    Ex: 78 Blazer 350,TH350,NP203............
    78 Truck 350,TH350,NP203............
    Don't they have the same front driveshaft ?
    or
    Ex: 87 Blazer 350,700r4,NP208.............
    87 Truck 350,700r4,NP208............
    Don't these also use the same front driveshaft ?
    Please corrent me if I am missing it.
    TIA
  5. '73 K5
    1,763
    Kansas
    I didn't say so but I was thinking about the rear shaft too. Usually when you have to change the front driveshaft, the rear must be lengthened too. With a 6 inch lift on a K5 I'd change both. On a longbed pickup, just the front.
    '73 K5
  6. Executioner
    Feb 22, 2000
    1,530
    I am confused I thought we were talking about the front driveshaft !
    Don't you just love this wounderfull thing call reading and writing over the internet ?
    Good thing no one beleives every post they read !
    Now if one hunderd post say the same thing then maybe you can ! , but then again maybe "NOT"
  7. '73 K5
    1,763
    Kansas
    What's your problem Executioner? I gave my opinion about the front AND rear shafts. Does that extra info bother you? Or is it the fact that I misspoke and corrected myself? I'm just trying to help the guy that posted the question as much as possible.
    Are all of your posts 100% correct? I doubt it.
    I have an idea. Instead of you complaining about the accuracy of the folks that use this website, you could quit reading it instead.
    '73 K5
  8. Executioner
    Feb 22, 2000
    1,530
    Sound like a good idear !
    By Bye
  9. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I would have to say yes. I'm planning on new ones with a 4". It just seems like good insurance. You might be able to get away without doing it but I wouldn't think so.
    Best way to tell for sure is to put the lift on and see how much spline engagement you have left. That would be the only sure fire way to tell.
    Hope some of this confusion helps
    Kyle
    89K5
  10. Kyle89K5
    2,273
    OKLAHOMA
    Looks like the we got a case of Board Rage going on. Ain't no need to get pissed at each other. Grain of salt guys. There is no need to turn an informative forum in to a pissing contest.
    COME AWN!!!!!!!!
    Kyle
    89K5
  11. 3030
    3030 Registered Member
    Feb 18, 2000
    14
    Sulphur Springs, Tx.
    After putting on a lift, what is the minimum amount of spline engagement that should be acceptable.
    There ain't no way I'll get stuck in that hole.....oops.
  12. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Here is a idea. Determine which trucks have longer shafts either the P/U's or Burb's and get those from a junk yard (if they are inexpensive) and have them shortened. If you have your shafts re-tubed it gets pretty expensive.
    Just a thought to save some fellow K5er's some money.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    As far as the front shaft goes.. I have a 6" lift and I have a 1" spacer on mine front shaft and it could be a little bit longer.
    The front drive shaft should be the sam on a Blazer AND a p/u if they both have the same drivetrain compenents! From the front bumper to the t-case the Blazer and p/u are Identical........... So if you had a Blazer and a p/u both with a 350/T350/NP208 setup, they would bith use the SAME driveshafts.
    Mike
    82 GMC Jimmy "Emmett"
    IN TOO DEEP Off-Road Club
  14. Executioner
    Feb 22, 2000
    1,530
    Thank you
