Front driveshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 674x4, Oct 15, 2001.
  1. 674x4
    674x4 Registered Member
    Jul 30, 2001
    84
    Sour Lake, Texas
    What do ya'll usualy do for the front driveshaft after an 8in lift? on my 67 (72 frame) it doesn't come close and there is no CV joint, the angle looks pretty bad at full droop at the case. any suggestions
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Have a driveshaft made to specifically fit your application.....
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Quit shooting corn at me!
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  3. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    I know, i was just wondering because of the angle at the transfer case, if i get the shaft legnthend it will still be pretty steep.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They won't stay together. Take my word for it. My friend has the same problem. He's destroyed a half dozen of them already.
    Tim
  5. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    dropping the t-case wont help?
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    most people add a cv joint setup to the front...thats really the only way to run the extreme angles...check out high angle driveline...the guy that owns it is a member here...i think he goes by drivelinman or something like that...you could do a search for it
    Later
    Have you driven OVER a Ford lately?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, CV is the only way to fly on pre-76 trucks that came with that yoke up front.
    Tim
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    So did the older trucks (like my '71) come without a CV in the front?
    Just currious beacuse mine has one.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  9. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    No i think they came with them, think mine is rigged.
  10. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    ive seen the cv on post 76 trucks too...ive seen it used on rears in a lot of vehicles as well
    Later
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Here is a link to Jess's website. Great guy... also if you are a member in orange you get a discount I believe.
    http://coloradok5.com/gallery/captcrunch
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what the hell is caster? pinion angle? a rare cheese? ancient language of atlantis?
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  13. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    How do you become a Member in Orange?
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  14. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Click on the join CK5 at the top and send Steve $25.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I was told by a member of this site that the pre-76 trucks are the ones that didn't come with a flange up front.
    I can say for sure that the single U-joint doesn't last long in the front of my friend's truck....he has full time hubs and it destroys itself often before he even hits the mud, on the road on the way there. His angles are insane though.
    Tim
  16. Msquared
    Msquared Registered Member
    Oct 2, 2001
    37
    It\'s all a fog
    Caster (rough definition) is the inclination angle of the spindle, given by the upper and lower control arm to spindle points as comapred to vertical.
    How you measure that on solid axles, I have a good idea, but I'll stay in my little corner and let those more knowledgeable than I answer.
    How you correct it? I have no clue on a solid axle.
    What it affects? The amount your steering wheel wants to return to center after turning, as well as to some extent, the amount steering effort you will need to use to turn the steering wheel off of center.
    It's that whole "car" thing again...
    Pinion angle is the angle of the pinion flange (on the axle) or degree of tilt the pinion has in relation to the other end you are attaching it to. In your situation it's that nifty transfer case thingamob...
    When you have it wrong, you know it! Bad vibrations through the suspension and driveline.
    rare cheese? a good one...
    Ancient language of atlantis? Chicken....
    -Marcus
    -Just me, trying to have fun
  17. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    got the driveshaft lengthened and the damn yoke hits the straps. any suggestions for the cheapest way out?
  18. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    just a guess but you may consider lowering the t-case as stated earlier. That is a mean angle, I hope it last for you....
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  19. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Lowering the tcase will actually hurt your frt shaft angle. If the front u-jt is binding up the angle is too big so you will need to either shim the front pinion angle up more (shims are known for making the truck wander and cause alignment problems... at least w/ the larger degree shims) What size shim is in there now? I would try a 6 degree shim. It will probably handle like crude though. Other options I believe would be getting the knuckle turned (very expensive) or to look into one of the dual CV style shafts. These have a cv at each end of the shaft so it can run at almost any angle.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  20. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    what is the best way to measure the driveshaft angle at the transfer case and the axle?
