Front end GURU'S
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Oct 13, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Front end GURU\'S
    Ok here is the deal..
    I just ditched the sway bar tonight /forums/images/graemlins/thumb.gifand in the process I was pushing on the front side ot the blazer and I heard a popping sound and could see the hub moving a little like the rim was loose /forums/images/graemlins/blush.gif...So I took the hub apart and then tightened it back up and put it all back together and went for a ride and now it pulls to the left when I brake /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif...WTH..mike
  2. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Re: Front end GURU\'S
    ttt /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Which hub did you tighten up?
  4. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    maybe its to tight /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    COUld you give us a better description of what was moving? First of all, what were you "pushing on"? The bumper? Or something in the supension?
    Are you sure the play in the front wheel isn't ball joints/tie-rods? When the last time you re-packed your bearings? It sounds to me like you overtightened your front hub......
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I tightend the passenger side hub and it was finger tight when I rechecked it so I tightened it up but not to tight and when I went to work this morning it was ok not pulling....??? oh well
    Thanks for the help anyway... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
