Front end ID help
Discussion in 'The Garage' started by buckmtn, Aug 21, 2006.
  1. buckmtn
    buckmtn 1/2 ton status
    Oct 17, 2005
    288
    Stokesville,Va
    I went to look at a front end today and I'm not sure what the heck it is. The guy that had it didn't either. Maybe a good thing. It had a dana style differential cover. Held on by either 10 or 12 bolts I can't remember. It was eight lug with drum brakes. The hubs were like nothing I had seen looked like the flange off a 14 bolt with a selector knob for locked unlocked. Closed knuckle. Only thing I saw as far as stamping was a tag on the diff cover said 4.55. Sure I can get it for little bit of nothing. Maybe put under my K5? Any ideas. Conversions for brakes or knuckles?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Closed knuckle = skip it.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Most likely a closed knuckle Dana 44, pass unless you need some dead weight for winter wheeling or a boat anchor, maybe for free.
  4. buckmtn
    Oct 17, 2005
    288
    Stokesville,Va
    If I got it for next to nothing and cut the ends off welded on some dinnabear knuckles and swapped on some disc brakes would it be any count then. If it were a dana 60? Just a take out chevy dana 60 that needs to be rebuilt costs 800-1000$$$$.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Dedenbears would cost you $1000 for just the c's and knuckles.
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If you need a 60, I have two for sale.
  7. peterpan
    peterpan Registered Member
    Aug 18, 2006
    95
    WYOMING
    that sounds like a axle i had in a 74 1 ton dodge it was a closed knuckle dana 70 with drum brakes they have smaller axle shafts than a dana 60 and are not worth a crap for any thing even if they are free i traded that complete running dodge for a chevy dana 60 front end
  8. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    The tubes are probably smaller than what the inner C's are on a 60,and it will probably have coarse slpine axles 18 spline or something like that.You can dump more money in it trying to make something out of it than what a 60 would cost.I've seen it done before.
