Front - end Lubrication Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4by4bygod, Jan 15, 2004.
  1. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Hi All!
    I have an 87 k5, bone stock. How do ya lube the front u joints at the wheels? ( is ball joint the proper term? ) I don't see a zerk fitting, and I don't want to let them dry out and replace them again.
    Thanks, Tom /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    First of all, welcome to CK5, brother!!!!
    Now onto the u-joints. If they are still the factory joints then there's a good chance that they are sealed and are not serviceable. If they've been replaced they may have plugs in place of the zerks- you have to take the plugs out and install a zerk if you want to grease the joint, then replace the plugs when you're done.....
    There are also recessed fittings that you can buy for u-joints that require the use of a grease needle instead of a normal grease fitting adapter.
    Hope that helps!! /forums/images/graemlins/thumb.gif
