Front End Noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by taterblazer, Feb 3, 2001.
  1. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Couple of days ago when I would slow down or start up from a stop in town a clunking sound would come from the front of the vehicle. I could actually feel it through the vehicle. 88 Blazer. It stoped after I engaged 4wd then disengaged it. Any ideas?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Do you have auto hubs. From what I have heard they can and will engage on there own for no reason.And disengage for no reason. I have them to, but mine have not done that yet. I did go out and buy warn hubs for it. I just haven't put them on yet and probably won't untill I have a problem..
    Become one with nature.............Then marinate it..
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Check your crossmember bolts.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Also, check all your u-joints in all the driveshafts. I had a short bed truck once, and it had u-joint problems ALL THE TIME. Reason was the angle of driveshaft on the 4 inch lift I had it on. I changed a rear u-joint approx. every month. This sucked.
  5. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Umm, what's a crossmember..
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Its the metal bracket that holds up the tranny and t-case combo. Its bolted to the bottom of the frame. Four bolts hold it. These have been known to work loose sometimes.
