Front end popping noise....
Discussion in 'The Garage' started by broncoman6524, Dec 12, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ok when ever the truck is sitting and i crank the wheel about 2"to the left i can hear/feel a popping noise turnit back about 4" and it does it again. as i start to accelerate and try to do it it doesnt make the noise nor do i feel it. unless i turn realy quick and sharply.
    WTF!? could this be a loose tie rod or are my ball joints goin bad? I put a diff steering box on to see if that did anything and unless theyre both F*cked then idk. lol (it wasnt a new box)
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I was thinking pitman arm,until you swapped out boxes.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Check the frame for cracks around the steering box.
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i kept the same pitman arm. could i not have tightened the bolt enough? after i swapped boxes my steering got infinently tighter,
  5. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    There you go.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine makes that noise and it is the bottom leaf in the spring pack slipping back and forth. The only way to check it is to have some one move the wheel while you look at **** under the hood.
    Ira
  7. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    x2 on the leaf packs. mine made the same popping noise from the springs. swapped springs and it went away for the most part. still does it every once in a while but not very often.
  8. 1-bad-burb
    1-bad-burb Registered Member
    Jun 23, 2005
    93
    west virginia
    X3 on the spring packs, my suburban did that for awhile and I thought the frame was cracked:doah: turned out one of the drivers side ubolts wasnt tightened down enough
  9. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    I had a cracked steering arm, until it snapped, luckinly i was parked. BUT now i have the same kind of noise, maybe i will check my leaf springs like everybody says.
  10. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    My truck was making that sound too. the driver side u-bolts were not tight. After I tightend them it would still make a slight popping sound turning to the left. thats when I found a crack between two of the bolt holes in the frame behind the steering box. mending plates fixed that.
  11. drop the hammer
    drop the hammer 1/2 ton status
    Feb 26, 2006
    160
    Massachusets
    CRAP Mine is making tha same noise and same feeling in the steering, only turning left and it feels like the wheel is draging a hair when I turn that way
  12. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    what do you do to solve this? just tighten the u-bolts or is there more to it?
  13. wwcnd
    wwcnd Newbie
    May 19, 2006
    idaho
    My old man's 82' did the same thing. We started with ball joints, went to wheel bearings, steering U-joints, and tie rods. Nothing worked, so we went to the springs. We put poly bushings in and it solved it. So I agree with the others, check the springs
  14. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    it is my springs and they already have polys...idk maybe tis the aal coming loose and kinda floppn lol.
  15. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    shot in the dark... body mounts?
  16. sandawgk5
    Oct 28, 2003
    6,881
    I dunno I havent done anything. I would imagine that you could replace the center pin with an allen bolt and get it way tight. A 3/8 cap screw is the same size as a leaf spring center pin and is what I run on my rear springs. I just have not taken the time to do the front.
    Ira
  17. ChickenRammit
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    its funny because thats exactly what i did, and i just now read this.
  18. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    I found that my driverside spring perch's center hole had become elongated from ubolts being loose. New perch, Old news
