front end question
Discussion in 'The Garage' started by 79BRUISER, Sep 24, 2006.
  1. 79BRUISER
    79BRUISER 1/2 ton status
    Jul 6, 2006
    739
    Indiana
    Looked at an 85 k5, 4 inch susp lift, 31.5 x 10.5 x 15 tires, stock axels and drivetrain
    Now for the question: When turning the steering wheel stop to stop is the front end, from the frame up, supposed to lift up about an inch?:confused:
    Didn't look right to me.
    please let me know whay you all think.
    Thanks, Bruiser
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    not sure if its suppose to but mine does it. when you turn left the passenger side rises and the driver side falls. opposite when you turn right.
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I would check for frame cracks around the steering box.
    -Harrison
  4. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    mine has no cracks. Ive checked it at least a dozen times, even cleaned it off real good and still saw none.
  5. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    normal. it is the Caster spec of the alignment you are pivoting.
  6. 79BRUISER
    Jul 6, 2006
    739
    Indiana
    thanks for the info
    bruiser
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    X2
    Cracks at the frame where the steering box mounts are really common though
