Front end woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80blazer, Apr 2, 2001.
  1. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    Hi all: I have a problem, I just took the blazer out to check out the 4x4 and it failed. I locked in the hubs and they made the infamose clicking noise in two wheel drive. I then shifted into 4x4 the clicking went away but when I tried to climb a steep hard packed hill the clicking came back and, the front did not pull. I bought the truck without the motor and do not know if the hubs worked (the hubs I believe are factory spicer). I do know the front driveshaft turns and the axel shafts lock in while in 4x4. My question is are the hubs toast or did I not put them back together right. Thank you for your help.
    Its time to lock them in!
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The only problem I've ever had with my Spicer hubs was when the grease got all gummy on me and they would not move freely enough inside. All I did was clean them out and re-grease them...
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    One other thing with Spicers(and some others) is that if you dont put them together right, the gears inside wont mesh and wont lock together.
    Get a Haynes or Chilton manual and see if they are together right....
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. 80blazer
    Mar 4, 2001
    41
    glendale arizona
    Thanx I pulled them apart a week ago and cleaned the heck out of them, but one thing i noticed was the plastic dial was worn pretty bad. Could this have something to do with not holding. Thank you for your help.
  5. dyeager535
    26,980
    Went to move my truck with no rear driveshaft and got the nice clicking from the front hubs. I bought some used Spicer hubs, but didn't even know they were supposed to have a spring "retainer"...not enough preload to engage the hubs.
    Dorian
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I thought greasing hubs was a no no!
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Seems like there is an ongoing controversy about whether to grease hubs or not. The instructions that come with the aftermarket lockout hubs simply state NOT to grease the lockouts....they come from the factory pregreased. Now if someone had to clean the hubs and needed to grease them again, they should just wipe the contact surfaces with light coating of grease by fingertips. Do NOT glop on the grease. Just a little bit of grease goes a long way in maintaining the life of a lock out hub.
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I've heard of guys using atf too... but have never tried it.
    1987 Chevy K5 Blazer- 350 TBI
