Front Fender Seperation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Aug 21, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    My right side fender has a dent that I'd like to pound out (no, I don't want THAT much character in my rig), but in order to do so, I need to remove the fender and seperate the outer and inner skins. Anyone done this before? The upper area where the two meet (the area that the hood covers) appears to be bonded together somehow. I'm used to having bolts along the top, but my '83 looks to be tack or pinch welded from the factory every foot or so. Thanks
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. dyeager535
    26,979
    IIRC, if you can't see the dent from the inside, with the fender removed, you can't get at the dent. The only bolt on piece is the inner fender. : (
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    if you can get to the area from the inside just use a metal cutting hole saw and make an access and you can beat on it with the fender in place
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Does it have a crease in the dent, or is it at the body line. If not and it is just a pressure dent like something just pushed it in, go to the bathroom and get the plunger and stick it on and give it a good pull. Don't laugh because this does work sometimes just ask Donna. I did this on one of her old cars and she laughed up untill I popped the dent out.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    If you do end up having to take off the inner, it's spot welded and you'll probably want to get a spot weld cutter. You can get 'em to go on drills, air tools, etc. Fun, fun!
    John
  6. beefcake83
    Jun 24, 2000
    240
    Alaska
    Well, unfortunately the dent is fist size and is located right behind the headlamp at the front of the fender. Just a tight area to try to get to. Probably half an inch deep. - Gary
    Gary Graham
    Eielson AFB, Alaska
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look in the Yellow Pages to see if you have a "Paintless Dent Removal" type of place in your area. They do big business in Colorado due to the high incidence of hail storms in the summer. They have special tools that can reach into some pretty tight areas and then massage out the dent.
    Most regular body shops will recommend against trying to work out a dent on a fender. The cost of labor to fix the dent usually exceeds the cost of installing a new fender. [​IMG]
