front floor pans
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 02trublu, Nov 24, 2002.
  1. 02trublu
    02trublu Registered Member
    Aug 26, 2002
    19
    minnesota
    ok, i've done a search and haven't come up with an answer. where do i find front floor pans with the seat bolt holes? part number would be sweet or any help would be appreciated. its for my newly acquired 91 k5 /forums/images/graemlins/cool.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    LMC part # 38-7946
    38-7947
    I think.... /forums/images/graemlins/wink.gif 79.95 each
    phone # 1 800 222 5664
  3. 02trublu
    Aug 26, 2002
    19
    minnesota
    sweet, thank you. is that a full floor pan or just the center section?
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    Its the two sides, did you order the catalog (it's free)it's full of all kinds of cool things...
    Something that might also help would be to check the links page and there is a post in the garage full of links but you have to be a member I think /forums/images/graemlins/confused.gif well worth it if you do... /forums/images/graemlins/thumb.gif
  5. 02trublu
    Aug 26, 2002
    19
    minnesota
    i ordered the catalog today, so it should be here in 2 weeks
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Oops it's this forum... /forums/images/graemlins/thumb.gif
  7. 02trublu
    Aug 26, 2002
    19
    minnesota
    ordered the parts today from lmc. thanks for your help chevyfumes
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I think the front pan stops short of the seat bolt holes. You might want to check the dimensions before you order. I had to have mine cut out and new flat pieces welded in.
    Try this Floor part
    You might try calling them I dont know if its right or not
  9. 02trublu
    Aug 26, 2002
    19
    minnesota
    well the parts i ordered were the rear half of the cab floor sections i guess we'll see this weekend
  10. 02trublu
    Aug 26, 2002
    19
    minnesota
    i got my floors pans today. they are the right ones except they don't have the seat mount holes in them. i will figure that out though. thanks chevyfumes!
  11. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so what are they the rear section...im just planning on putting my own sheet medal in..does the job..and its free! just gatta get some new innner/outer rocker panals..
  12. 02trublu
    Aug 26, 2002
    19
    minnesota
    where the floor goes 90 degrees up in the back, it starts there and is about 4 inches high. it ends right in front of where the front seat bolts are, right where the front floor pan would end. sounds confusing but i don't know how else to describe them
