Front Ford D60 ?'s
Discussion in 'The Garage' started by 88K5Jimmy, Oct 27, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Front Ford D60 ?\'s
    Could you swap the center section of the D60 to the passenger side by taking out the axle tubes and switching sides along with the axle shafts? Would this work or is there something I am overlooking? /forums/images/graemlins/confused.gif
  2. tonto
    tonto Registered Member
    Feb 12, 2002
    50
    oklahoma
    Re: Front Ford D60 ?\'s
    your missing that the spring perch is cast into the side of the carrier. you are close to wagoneer machine shop, they do a spring clamp for this i think it starts around $250. have seen some of their work, very top notch.call them and they can tell you the rest, located in claremore.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can save a bunch of work by swapping to a NP241C from an IFS truck (driver-side drop). Easy t-case to find.
    Make sure you get the Ford Dana 60 from a 78-79 truck - I believe it will bolt right onto the Chevy springs. (Can anyone confirm this?)
    A newer (86-up) Ford Dana 60 has the pumpkin closer to the wheel, so you'd have to cut it up, or outboard your springs. /forums/images/graemlins/blush.gif
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I believe the 78-79 style have a 32" center to center spring pad while the later ones have a 36". With the 36", if you run a tire larger than 38", you can run into problems with your tires rubbing on the spring packs at full lock /forums/images/graemlins/blush.gif. Heres my 79:
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Hey willyswanter
    Do you have a pic of where the spring perch mounts on the driver side pumpkin?
  6. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    This is about the closest one I have:
    I can take one tomorrow but it's on the truck now and the springs are bolted on...
  7. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    if you wanted to use a doubler caint you also use a furd 205 with driver side output and it work??
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    If you had the time I would like to see a close-up pic of where the spring perch is on the housing.
