Front frame crossmenber
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by clarkekent, Apr 25, 2002.
  1. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    I'm in the process of straightening the frame on my '72 blazer after an accident. Does anyone have good pics of the front frame crossmember? Does anyone make new ones?
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    which crossmember? the one that the engine sits on the one ahead of that?
  3. clarkekent
    Sep 26, 2000
    69
    NY
    The very front crssmember. The accident only damaged the frame from the shock mount forward.
  4. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    If thats the case, then it took out both your crossmembers.
  5. clarkekent
    Sep 26, 2000
    69
    NY
    The engine crossmember is intact and not bent.
    The front crossmember is shaped in a V to begin with... I just need help judging how V-shaped it should be.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the way to fix that would be to know the distance that the frame rails are supposed to be spearated by, the V wil be as big or small as it needs to be when the rails are separated by correct original distance, need ot get that distance from someone with same truck as you,
    i think i explained correctly,
  7. kilomanjaro
    kilomanjaro 1/2 ton status
    Feb 22, 2000
    229
    Manhattan, Ks USA
  8. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Look at my frame at the link in my sig. If those don't help, let me know, and I can take more pics
