Front Hub Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Mar 28, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I was taking apart my front hubs on my Suburban and I noticed there was no spring behind the locking mechanism. It's a '90 3/4 ton with a 10 bolt front. I couldn't find anything in my Haynes manual, it stopped at '87.
    My questions are:
    Are the stock locking hubs supposed to have springs in there?
    What are the torque specs for the bearings?
    What is the procedure for torqing them?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If you have one of those auto locking hubs, I have no idea. But if it's a manual locking hub, then yes, there is supposed to be a spring in there somewhere.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    You have a large spring, not removable and a smallerone in the cover.
    I screw the nut always firmly on and open it then around a ¼ turn. Thereafter the wheel should be able to turn itself freely and should have no lateral play. The examination goes more easily if you press back the pistons of your brake caliper before.
    In any case, use for the nut a special tool. Screwdrivers, chisels and hammer destroy them.
  4. Richard- sent you some diagrams. Hope it helps.
    Mat
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    RICHARD GET TO WORK!!!! WE NEED TO FINISH THE BORE SITE!!!!
  6. chvyhs
    Feb 12, 2001
    1,469
    It's "boresight" and I'm done now.
