Front hubs heating up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5chevy, Sep 2, 2001.
  1. k5chevy
    k5chevy Newbie
    Sep 2, 2001
    3
    Northwest Florida
    Does anyone know why my hubs would get so hot they smoke??? Its a 79 with a Dana 44 full time converted to part time. My buddy says that I have to take out the spring that disengages the locking cog. Not to sure about that one! If any of you guys know, I'd love to know, too. Never had this problem before.
    Build it, Break it, Better it.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sounds like you hubs are going bad. I would buy a new set and that would fix the problem.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Check your wheel bearings and make sure they have plenty of grease. I had the same problem right after I got my Blazer. The bearings hadn't been touched in years. New bearings and grease solved my problem.
  4. k5chevy
    k5chevy Newbie
    Sep 2, 2001
    3
    Northwest Florida
    I re-pack the bearings, but didn't replace them, waiting for the money!
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    dont drive it anymore until you fix it please
  6. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    It could be the brakes/rotor getting hot and tranferring the heat to the hubs, make sure the pads are releasing from the rotor...but I'd go with the bearings, if you off-road alot use marine grease to repack then stuff the hubs full, it'll keep the water out, and what water gets in will not wash out the grease.
    And DON"T DON"T DON"T drive it untill you've checked this, you lock up a bearing and goodbye spindle and God only knows what else...thats gonna be$$$$$$$$$$
    Later
    Veni Sancte Spiritus
    Da Pacem Cordium
    White Knight
  7. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I am willing to bet this is what's happening:
    when you repacked the bearings, you may not have gotten the locator pin on the inner spindle nut to go through one of the holes in the lock ring. This will cause the lock ring to be cocked off a little, and thus, the outer nut can not screw on to the spindle far enough.
    The outer spindle nut is actually rubbing on the clutch ring in the lock out hub, and that is causing the heat. It can also cause your hub to lock in while you are cruising down the highway. This will jerk the wheel in the direction of the hub that locks, obviously a potentially dangerous situation.
    If this is not the case, then it must be the brake calipers sticking like White Knight said.
    Either way, tell your friend (the spring removal specialist) to shut up. The springs turn with the rotor, and consequently, they also turn with the clutch ring, so no friction can occur between these parts.
    Lift It, Lock It, LIVE IT!!!
