front leaf shackle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5blazin, Apr 23, 2007.
  1. 88k5blazin
    88k5blazin 1/2 ton status
    Nov 27, 2006
    484
    clark new jersey
    is this a normal angle for the shackle on a 12 inch leaf spring on an 88 k5 with the ord shackles
  2. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    My 8" superlift springs (stock length) with 6" shackles look like that also. Also have the FUSH.
  3. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    yup, that's about normal. you can move the rear hanger forward, like what is done when you do the 52" spring swap, and it will help your flex and ride better.
  4. 88k5blazin
    Nov 27, 2006
    484
    clark new jersey
    springs
    is it just grinding off the rivets and drilling new holes a little further or is there anything else to the process cause if it'll make it ride better anything to get a little nicer ride would make it better
  5. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    ya, you just move the hanger forward using the upper, forward most hole already there to position the hanger, and drill new holes. you will need to make longer shackles also. read up on the 52" spring swap. your just not using those springs.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Is this a cummins?
  7. justiz00
    Dec 11, 2006
    83
    Central Texas
    Yes, a 92 block.
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yumm cummins
