FRONT LEAF SPRING BOLT?
Discussion in 'The Garage' started by JROSS, Dec 8, 2003.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    Need quick answer before lunch if possible.
    What is the size of the front leaf spring, front mount, bolt. I had to cut one out and left the good one at home to compare. I know its about 5" but whats the dia. I need to get this at lunch to finish the install tonight. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    /forums/images/graemlins/thumb.gif
  4. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Hmmm, I thought they were 1/2" /forums/images/graemlins/thinking.gif
  5. JROSS
    Oct 12, 2001
    281
    Redding, CA
    Thanks for the quick replies. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Front springs= 9/16 at front 7/16 at shackles and frame
    Rear springs= 9/16 (all)
    Bushings and sleeves are 3" wide (all)
  7. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    I thought when I used the ORD stuff, they were all 1/2", oh well /forums/images/graemlins/thinking.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    Yup, ORD uses 1/2" bolts. That's a step up by 1/16" on the upper bolt (the one through the frame), but a step down by 1/16" on the lower bolt (the one through the spring). I opted to drill out the lower shackle holes to 9/16" so I could use my existing spring bushings and beefier 9/16" bolts. I guess I'd like to see ORD make both upper and lower 9/16"...but, I don't run the company, so I don't get to make decisions like that. /forums/images/graemlins/crazy.gif /forums/images/graemlins/rotfl.gif
